Discuss
fixing spring on Bosch dishwasher detergent dispense
 in
Dishwasher Repair
I found the spring on my dishwasher dispenser sticking out of a hole on the dispenser door and while I
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » fixing spring on Bosch dishwasher detergent dispense
  #1 (permalink)
Old 08-25-2008, 02:11 PM
adobemama adobemama is offline
Junior Member
adobemama is on a distinguished road
Default fixing spring on Bosch dishwasher detergent dispense
Brand: Bosch   Age: 1 - 5 years
I found the spring on my dishwasher dispenser sticking out of a hole on the dispenser door and while I can close the dispenser door, it's obvious the spring isn't working correctly-- no spring action . I believe it's not in the correct place.
I've attached a jpeg photo of how I found the spring. any suggestions on how to put it back into place?
thx
PS the detergent does seem to be emptied out at the end of the cycle --(most of the time) but the door remains closed. . .
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-30-2008, 07:10 PM
GoFastKindaGuy GoFastKindaGuy is offline
Junior Member
GoFastKindaGuy is on a distinguished road
Default I think this is how it works...
Pull the spring end out of the hole. Slide the two front guide pins down the tracks. Rotate the spring so it's centered over the pin. Pivot the cover until it is almost closed. (The rear guide pins are not in the tracks.) Lower the spring loop over the pin. It may snap in place over the pin -- reach in with the aid of a butter knife. Slide the door "more open" and you should feel the spring tension. Slide the two rear guide pins into the tracks. I think you'll be in business.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replacing Bosch Dishwasher Door Spring Pulleys MGouveia Dishwasher Repair 1 07-23-2008 08:29 PM
Whirlpool Dishwasher Detergent Dispenser Spring posterman Dishwasher Repair 0 07-10-2008 10:02 AM
how do you install the detergent lid spring Bill Cleveland Dishwasher Repair 0 03-19-2008 07:28 PM
Bosch Detergent Dispenser Martinlady Dishwasher Repair 3 01-10-2008 07:14 PM
Question about how to install detergent lid spring. jaholden Dishwasher Repair 1 11-19-2007 10:16 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
