I just received a replacement tub gasket for my KUDC25CHSS1 , and there is an additional part in the bag which my old gasket didnt have
It's a semi-clear band about the same diameter of the new gasket, looks like same stuff they make wire ties out of. Do I need to use this, if so how?
Another question, do I wet the new gasket before re-seating the motor pump assembly ?
thanks.
