Discuss
Whirpool Not spraying water
 in
Dishwasher Repair
Motor spins and lower spray arm moves freely..... With Outlet cover off I can see the motor spin down if
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Whirpool Not spraying water
  #1 (permalink)
Old 08-22-2008, 08:18 AM
Junior Member
iceman382 is on a distinguished road
Unhappy Whirpool Not spraying water
Model Number: gu980scgb   Brand: Whirlpool   Age: 5 - 10 years
With Outlet cover off I can see the motor spin down if I quickly open the dishwasher door. Tried using CLR cleaner on 1 wash/rinse cycle.
Not spraying water and cleaning dishes. Spray arm looks clean and so does power clean filter.
Any ides?
I Replaced Outlet #AP3964091 and same thing.
Thanks.
Robert
Ads By Google
Related Models
Whirlpool GU980SCGB0
Whirlpool GU980SCGB1
Whirlpool GU980SCGB2
Whirlpool GU980SCGB3
Whirlpool GU980SCGQ0
Whirlpool GU980SCGQ1
Whirlpool GU980SCGQ2
Whirlpool GU980SCGQ3
Whirlpool GU980SCGS1
Whirlpool GU980SCGS2
Whirlpool GU980SCGS3
Whirlpool GU980SCGT2
Whirlpool GU980SCGT3
Whirlpool GU980SCGZ0
Whirlpool GU980SCGZ1
Whirlpool GU980SCGZ2
Maytag GV1110PRW Range - F/s Std Gas
International GV1226NXEW Freezer - Vertical
International GV1726NXEW Freezer - Vertical
Hoover GV3177WUA Range - F/s Std Gas
Hoover GV3177WUA5 Range - F/s Std Gas
Hoover GV3177WUW Range - F/s Std Gas
Hoover GV3177WUW5 Range - F/s Std Gas
Maytag GV3277XUA Range - F/s Std Gas
Maytag GV3277XUW Range - F/s Std Gas
Hoover GV3531WUA Range - F/s Std Ele
Hoover GV3531WUW Range - F/s Std Ele
Whirlpool GVW9959KL0
Whirlpool GVW9959KL1
Whirlpool GVW9959KL2
Whirlpool GVW9959KL3 Automatic Washer
Whirlpool GVW9959KQ0
Whirlpool GVW9959KQ1
Whirlpool GVW9959KQ2
Whirlpool GVW9959KQ3 Automatic Washer
Whirlpool GVW9959KT0
Whirlpool GVW9959KT1
Whirlpool GVW9959KT2
Whirlpool GVW9959KT3 Automatic Washer
Maytag GW18F1 Washer - Top Loading
Maytag GW18F1A Washer - Top Loading
Maytag GW18F1H Washer - Top Loading
Maytag GW18F1W Washer - Top Loading
Maytag GW18F2 Washer - Top Loading
Maytag GW18F2A Washer - Top Loading
Maytag GW18F2H Washer - Top Loading
Maytag GW18F2W Washer - Top Loading
Maytag GW18G1 Washer - Top Loading
Maytag GW18G100 Washer - Top Loading
Maytag GW18G124 Washer - Top Loading
Maytag GW18G125 Washer - Top Loading
Maytag GW18G1A Washer - Top Loading
Maytag GW18G1HW Washer - Top Loading
Maytag GW18G1WW Washer - Top Loading
Maytag GW20F6 Washer - Top Loading
Maytag GW20F600 Washer - Top Loading
Maytag GW20F624 Washer - Top Loading
Maytag GW20F625 Washer - Top Loading
Maytag GW20F6A Washer - Top Loading
Maytag GW20F6H Washer - Top Loading
Maytag GW20F6W Washer - Top Loading
Frigidaire GW30SPEA2 Wwh(v1) / Electric Range
Frigidaire GW30SPED1 Wwh(v2) / Electric Range
Frigidaire GW30SPEW1 Wwh(v1) / Electric Range
Frigidaire GW30SPEW2 Wwh(v2) / Electric Range
Whirlpool GW395LEGB0
Whirlpool GW395LEGB1
Whirlpool GW395LEGB3
Whirlpool GW395LEGB4
Whirlpool GW395LEGB5
Whirlpool GW395LEGB6
Whirlpool GW395LEGQ0
Whirlpool GW395LEGQ1
Whirlpool GW395LEGQ3
Whirlpool GW395LEGQ4
Whirlpool GW395LEGQ5
Whirlpool GW395LEGQ6
Whirlpool GW395LEGT3
Whirlpool GW395LEGT4
Whirlpool GW395LEGT5
Whirlpool GW395LEGT6
Whirlpool GW395LEGZ0
Whirlpool GW395LEGZ1
Whirlpool GW395LEGZ3
Whirlpool GW395LEPB00 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPB01 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPB02 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPB03 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPB04 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPB05 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ00 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ01 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ02 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ03 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ04 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ05 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS00 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS01 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS02 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS03 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS04 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS05 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPT00 30" Slide - in Gas Oven Non - Convect
Whirlpool GW395LEPT01 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPT02 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPT03 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPT04 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPT05 30" Slide - in Gas Oven Non - Conv
Maytag GWC202 Dishwasher - Convertible
Maytag GWC204 Dishwasher - Convertible
General Electric GWR03AAMABB Refrigerator
Gibson GWS1149AS0 Washer - Gibson
Gibson GWS1149AS1 Washer - Gibson
Gibson GWS1339CS0 Gibson/washer
Gibson GWS1339CS1 Gibson/washer
Gibson GWS1749AS0 Washer - Gibson
Gibson GWS1749AS1 Washer - Gibson
Gibson GWS1749CS0 Gibson/washer
Frigidaire GWS223RFS0 Gib(v0) / Washer
Frigidaire GWS223RFS1 Gib(v0) / Washer
  #2 (permalink)
Old 08-22-2008, 08:48 AM
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
Check the check balls item # 7 on the pump & motor breakdown page.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Dishwasher spraying water out Air Gap truckinus Dishwasher Repair 1 02-22-2010 05:26 AM
Lots of water spraying from arms, but they don't spin rjs.napc Dishwasher Repair 3 12-03-2009 12:54 AM
Water Not Spraying kenmore2 Dishwasher Repair 1 08-13-2008 09:17 PM
water not spraying from the lower and upper arm, jamesg Dishwasher Repair 3 06-25-2008 09:41 AM
water not spraying from the lower and upper arm jamesg Dishwasher Repair 0 06-20-2008 04:33 PM
