I have a Kenmore dishwasher - model 665.13593K600. The normal wash light is constantly flashing/blinking. The dishwasher will not start a wash cycle. Sometimes if I press the heated dry button the pots and pans light will come on. When I press the normal wash button, the pots and pan light goes off. I read somewhere to push the sequence of normal wash, heated dry a few times, but the only thing that happens is when I heat the heated dry, the pots and pans light comes on. This morning all of the lights were off and when I pressed the normal wash it started a wash cycle. It's very intermitent which makes it even more difficult to diagnose. I located the diagnotic sheet behind the toe panel, but it only has wiring diagrams and does not help. Any help is appreciated.
