I need help locating the correct motor pump assembly for the GU2400xtpb6 model. How difficult is this replacement? I am going to attempt it myself. Thanks, Kim
Groups: Expert
Joined: 7/27/2010(UTC) Posts: 1,395 Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
Originally Posted by: suzieQ5 I need help locating the correct motor pump assembly for the GU2400xtpb6 model. How difficult is this replacement? I am going to attempt it myself. Thanks, Kim I think you are looking for this Part number: AP3778061
Its not too bad of a job. Its probably easiest to remove the dishwasher from under the counter. Take off the pump, wires, and pull the three wedges that hold the pump in place. Oh, before you do that, you should remove the feed tube assembly and pump top inside the dishwasher. This should show you how it goes together. Replacement parts for WHIRLPOOL GU2400XTPB6 Dishwasher | AppliancePartsPros.com
