Do I need to pull the washer out completely to access & remove the heater element? I see that the old element has inserts that protrude into the bottom of the dishwasher itself. They appear to either snap in or are otherwise secured from the bottom. If they merely snap in, then I can get them out by pulling hard I suppose. But if they are fastened from the bottom, I will have to pull the entire washer out from the cabinet so I can turn it on its side for access.
