I have a Maytag portable dishwasher which stopped draining. When I pressed the cancel button, the dishwasher would drain what ever water was in the tub. So when after running through a cycle, I pressed the cancel button to see if it would drain. It would only make a humming sound but no draining. All other cycles would work. My daughter made the mistake of running the dishwasher after I noticed the problem and it caused water to run out of the tub. I ordered a new drain pump and replaced the old one. The dishwasher ran fine for almost 2 weeks, then same problem. I replaced the new one and it ran okay for almost a week and then kerplunk! I replaced it last week and it ran for about 2 days and is on the fritz again. I put a bead of sealant around the pump mounting area to ensure there were no leaks. I have no idea what's going on. Any ideas?
