I am installing this unit used. When I first installed it, before I fastened it to the counter top, it leaked about 1 Tablespoon around right side of door at the bottom. After adjusting it and trying to level it, it now leaks a couple of ounces around the left side. I think I'm not getting it fastened in the opening squarely, but I've never had a problem with a unit being so sensitive. Any thoughts?
