Discuss
Kenmore Elite not draining
 in
Dishwasher Repair
I have a Kenmore Elite model# 15962990 that is not draining. It was working properly and then just stopped. when
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Kenmore Elite not draining
  #1 (permalink)
Old 07-28-2010, 02:54 PM
Junior Member
jrespen is on a distinguished road
Default Kenmore Elite not draining
Model Number: 15962990   Brand: Kenmore   Age: 1 - 5 years
I have a Kenmore Elite model# 15962990 that is not draining. It was working properly and then just stopped. when I try to drain it I hear a buzzing like the motor is trying to work, but is not spinning. it buzzes for a while and then shuts off. I checked to see if it was clogged and that is not the case. I have also reset several times to no avail. Any suggestions?
Ads By Google
Related Models
Amana 15A Freezer - Vertical
Amana 15B Freezer - Vertical
Amana 15C Freezer - Vertical
Magic Chef 15G-1-94 Range - F/s Std Ele
Magic Chef 15GA-1 Range - F/s Std Ele
Magic Chef 15GA-1-94 Range - F/s Std Ele
Magic Chef 15GA-1-GG Range - F/s Std Ele
Magic Chef 15GA-10 Range - F/s Std Ele
Magic Chef 15GK-1
Magic Chef 15GK-1-GG Range - F/s Std Ele
Magic Chef 15GK-10 Range - F/s Std Ele
Magic Chef 15GN-1 Range - F/s Std Ele
Magic Chef 15GN-1-94 Range - F/s Std Ele
Magic Chef 15GN-1-GG Range - F/s Std Ele
Magic Chef 15GN-10 Range - F/s Std Ele
Magic Chef 15GY-1 Range - F/s Std Ele
Magic Chef 15GY-1-GG Range - F/s Std Ele
Magic Chef 15GY-10 Range - F/s Std Ele
Magic Chef 15H-10-94
Magic Chef 15H-10-GG
Magic Chef 15HA-10 Range - F/s Std Ele
Magic Chef 15HA-10-94 Range - F/s Std Ele
Magic Chef 15HA-10-GG Range - F/s Std Ele
Magic Chef 15HK-10
Magic Chef 15HK-10-94
Magic Chef 15HN-10 Range - F/s Std Ele
Magic Chef 15HN-10-94 Range - F/s Std Ele
Magic Chef 15HN-10-GG Range - F/s Std Ele
Magic Chef 15HY-10 Range - F/s Std Ele
Magic Chef 15HY-10-94
Amana 16 Freezer - Vertical
Amana 16-3SPMK Room Air Conditioner
Amana 1607.000 Mwave - Family Size (60 Hz)
Amana 1607.001 Mwave - Family Size (60 Hz)
Amana 1608.000 Mwave - Family Size (60 Hz)
Amana 1608.001 Mwave - Family Size (60 Hz)
Amana 1608.002 Mwave - Family Size (60 Hz)
Amana 1608.004 Mwave - Family Size (60 Hz)
Amana 1609.000 Mwave - Family Size (60 Hz)
Amana 1609.001 Mwave - Family Size (60 Hz)
Amana 1618.000 Mwave - Family Size (60 Hz)
Amana 1618.001 Mwave - Family Size (60 Hz)
Amana 1618.002 Mwave - Family Size (60 Hz)
Amana 1618.004 Mwave - Family Size (60 Hz)
Whirlpool 1633W0A
Whirlpool 1633W1A
Whirlpool 1633W2A
Whirlpool 1633^0A
Whirlpool 1633^1A
Whirlpool 1633^2A
Amana 1635.000 Mwave - Family Size (60 Hz)
Amana 1635.001 Mwave - Family Size (60 Hz)
Amana 1636.000 Mwave - Family Size (60 Hz)
Amana 1636.001 Mwave - Family Size (60 Hz)
Amana 1639.000 Mwave - Family Size (60 Hz)
Amana 1639.001 Mwave - Family Size (60 Hz)
Amana 1639.002 Mwave - Family Size (60 Hz)
Amana 1639.004 Mwave - Family Size (60 Hz)
Whirlpool 1643W0A
Whirlpool 1643W1A
Whirlpool 1643W2A
Whirlpool 1643^0A
Whirlpool 1643^1A
Whirlpool 1643^2A
Whirlpool 1653W0A
Whirlpool 1653W1A
Whirlpool 1653W2A
Whirlpool 1653^0A
Whirlpool 1653^1A
Whirlpool 1653^2A
Hoover 168691 Electrolux/refrigerator
Magic Chef 16RA-3B Rv Range - Gas
Magic Chef 16RA-3B-49 Rv Range - Gas
Magic Chef 16RA-3BK Rv Range - Gas
Magic Chef 16RA-3BKZ Rv Range - Gas
Magic Chef 16RA-3BT Rv Range - Gas
Magic Chef 16RA-3BT49 Rv Range - Gas
Magic Chef 16RA-3BTZ Rv Range - Gas
Magic Chef 16RA-3BZ Rv Range - Gas
Magic Chef 16RA-4 Rv Range - Gas
Magic Chef 16RA-4K Rv Range - Gas
Magic Chef 16RA-4KZ Rv Range - Gas
Magic Chef 16RA-4T Rv Range - Gas
Magic Chef 16RA-4TZ Rv Range - Gas
Magic Chef 16RA-4Z Rv Range - Gas
Magic Chef 16RB-3B Rv Range - Gas
Magic Chef 16RB-3BK
Magic Chef 16RB-3BKZ
Magic Chef 16RB-3BT Rv Range - Gas
Magic Chef 16RB-3BTZ Rv Range - Gas
Magic Chef 16RB-3BZ Rv Range - Gas
Magic Chef 16RB-4 Rv Range - Gas
Magic Chef 16RB-4K
Magic Chef 16RB-4KZ Rv Range - Gas
Magic Chef 16RB-4T
Magic Chef 16RB-4TZ Rv Range - Gas
Magic Chef 16RB-4Z Rv Range - Gas
Magic Chef 16RS-4 Rv Range - Gas
Magic Chef 16RS-4K Rv Range - Gas
Magic Chef 16RS-4KZ
Magic Chef 16RS-4T Rv Range - Gas
Magic Chef 16RS-4TZ
Magic Chef 16RS-4Z Rv Range - Gas
Magic Chef 16RW-3B Rv Range - Gas
Magic Chef 16RW-3B-49 Rv Range - Gas
Magic Chef 16RW-3BK Rv Range - Gas
Magic Chef 16RW-3BKZ Rv Range - Gas
Magic Chef 16RW-3BT Rv Range - Gas
Magic Chef 16RW-3BT49 Rv Range - Gas
Magic Chef 16RW-3BTZ Rv Range - Gas
Magic Chef 16RW-4 Rv Range - Gas
Magic Chef 16RW-4K Rv Range - Gas
Magic Chef 16RW-4KZ Rv Range - Gas
Magic Chef 16RW-4T Rv Range - Gas
Magic Chef 16RW-4TZ Rv Range - Gas
Magic Chef 16RW-4Z Rv Range - Gas
Magic Chef 16TA-3B-49 Rv Range - Gas
Magic Chef 16TA-3BK49 Rv Range - Gas
Magic Chef 16TA-3BZ Rv Range - Gas
Magic Chef 16TA-4Z Rv Range - Gas
  #2 (permalink)
Old 07-28-2010, 06:03 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Does it wash?
Remove the bottom access panel and check if there are a water marks on the motor. If there are any, replace the pump & motor assembly.
- The pump & motor assembly Part number: AP3776467
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 07-28-2010, 06:52 PM
Junior Member
Default
Thanks Gene,
A pricey part, but it looks like the right fix. I pulled the cover off and the motor is corroded. Looks like this has been going on for a while.
thanks again,
  #4 (permalink)
Old 07-28-2010, 07:21 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome.
It is expensive but at least it's not too difficult to replace it yourself. Keep us posted.
__________________
  #5 (permalink)
Old 08-07-2010, 01:31 PM
Junior Member
Default
I finally found time to install the new motor. Works great, and was an easy swap. However the new motor does make a clicking sound as if the impeller is hitting something internally. I hope that is not a sign that the motor will fail already? Thanks for the help Gene.
  #6 (permalink)
Old 08-07-2010, 01:59 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome. It's hard to say why the new pump makes such noise. One of possibilities is if a foreign object got inside. Hopefully it will go through after a few cycles.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Dishwasher not draining Satisfied Dishwasher Repair 0 10-06-2009 09:25 AM
Kenmore not draining completely csohio Washer Repair 1 12-23-2008 01:36 PM
Kenmore not draining or spinning Alicornat Washer Repair 2 07-20-2008 08:45 AM
Kenmore Dishwasher not draining landlord128 Dishwasher Repair 1 02-21-2008 11:27 AM
Kenmore Dishwasher not draining hspotts Dishwasher Repair 0 01-19-2008 02:19 PM
