Had an issue where i took out the control module, saw the infamous burned out pin in the baord, soddered it, and sat back to pat myself on the back . Problem now is that I took off the entire door to get ot the board. And Im having a heck of a time getting the door on. I already rippped apart one of the plastic hinges that holds the rubber seal in palce (just ordered a new one), and I bruised my hand in trying to smack the door in palce but to no avail. Are there any good tips on how to get the dang door back on properly? Should I use wood chocks to hold the hinges open and slide the door in? Should I ake the hinges off , put them on the door, and THEN get the door on? Any help appreciated!
Thanks!
