I have a KUDSO1IJBSO Dishwasher that shows a flashing "Rinse Only" indication. I purchased a new control panel only to find out it is only a swithch panel. I would like to know if I need the circuit board or should I try to use the switch panel. I ohmed the door swithch and it seems to work. I can make the unit work intermittently by openinng up the panel assembly.
