Discuss
No water from spray arms
 in
Dishwasher Repair
I purchased my home 2 years ago and the dishwasher came with the home, so I'm guessing at the 5
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » No water from spray arms
  #1 (permalink)
Old 08-13-2008, 06:20 AM
Junior Member
Junior020477 is on a distinguished road
Default No water from spray arms
Model Number: KUD1TJWH0   Brand: Kitchen Aid   Age: 1 - 5 years
I purchased my home 2 years ago and the dishwasher came with the home, so I'm guessing at the 5 years for the age of it. Recently, I noticed the dishes not being cleaned properly. The dishwasher runs through it's full cycle...the dishwasher fills with water, heats the water, runs through the cycle, then drains. The problem is that no water is coming up through the spray arms. I have disconnected the spray arms and feed tubes to check for debris/blockages and found none. I disassembled the lower screen down to the chopper assembly and removed any foreign material found, but this has not helped. It seems that when the dishwasher cycle reaches the wash, there is a slight humming noise coming from the dishwasher. Is this the Pump Motor Assembly not functioning properly? Could this be caused by debris in the impellors and subsequently fixed? Or, will this require complete replacement of the motor assembly? How difficult is this to do? Is there also a seal kit that needs to be replaced while replacing the pump?
Ads By Google
Related Models
Whirlpool KUDA03CTBL0 Undercounter Dishwasher
Whirlpool KUDA03CTBL1 Undercounter Dishwasher
Whirlpool KUDA03CTBL2 Undercounter Dishwasher
Whirlpool KUDA03CTBS0 Undercounter Dishwasher
Whirlpool KUDA03CTBS1 Undercounter Dishwasher
Whirlpool KUDA03CTBS2 Undercounter Dishwasher
Whirlpool KUDA03CTWH0 Undercounter Dishwasher
Whirlpool KUDA03CTWH1 Undercounter Dishwasher
Whirlpool KUDA03CTWH2 Undercounter Dishwasher
Whirlpool KUDA210S0
Whirlpool KUDA220T0
Whirlpool KUDA220T1
Whirlpool KUDA220TWH0
Whirlpool KUDA220TWH1
Whirlpool KUDA220TWH2
Whirlpool KUDA220TWH3
Whirlpool KUDA220TWH4
Whirlpool KUDA220TWH5
Whirlpool KUDA220TWH6
Whirlpool KUDA22ST0
Whirlpool KUDA22ST1
Whirlpool KUDA22ST2
Whirlpool KUDA22ST3
Whirlpool KUDA22ST4
Whirlpool KUDA22ST5
Whirlpool KUDA22SWWH0
Whirlpool KUDA22SWWH1
Whirlpool KUDA22SWWH2
Whirlpool KUDA230YAL0
Whirlpool KUDA230YAL1
Whirlpool KUDA230YAL2
Whirlpool KUDA230YWH0
Whirlpool KUDA230YWH1
Whirlpool KUDA230YWH2
Whirlpool KUDA23HB0
Whirlpool KUDA23HBWH0
Whirlpool KUDA23HYAL0
Whirlpool KUDA23HYWH0
Whirlpool KUDA23HYWH1
Whirlpool KUDA23SB0
Whirlpool KUDA23SBWH0
Whirlpool KUDA23SY0
Whirlpool KUDA23SY1
Whirlpool KUDA23SY2
Whirlpool KUDA23SYWH0
Whirlpool KUDA23SYWH1
Whirlpool KUDA23SYWH2
Whirlpool KUDA23ZY0
Whirlpool KUDA23ZY1
Whirlpool KUDA23ZYWH0
Whirlpool KUDB03CTBL0 Undercounter Dishwasher
Whirlpool KUDB03CTBL1 Undercounter Dishwasher
Whirlpool KUDB03CTBL2 Undercounter Dishwasher
Whirlpool KUDB03CTBS0 Undercounter Dishwasher
Whirlpool KUDB03CTBS1 Undercounter Dishwasher
Whirlpool KUDB03CTBS2 Undercounter Dishwasher
Whirlpool KUDB210S0
Whirlpool KUDB210S1
Whirlpool KUDB210S2
Whirlpool KUDB21S0
Whirlpool KUDB220T0
Whirlpool KUDB220T1
Whirlpool KUDB220T2
Whirlpool KUDB220T3
Whirlpool KUDB220T4
Whirlpool KUDB220T5
Whirlpool KUDB220T6
Whirlpool KUDB22HT0
Whirlpool KUDB22HT1
Whirlpool KUDB230B0
Whirlpool KUDB230Y0
Whirlpool KUDB230Y1
Whirlpool KUDB230Y2
Whirlpool KUDB23HB0
Whirlpool KUDB23HY0
Whirlpool KUDB23HY1
Whirlpool KUDB23HY2
Whirlpool KUDC01TMBL0 Undercounter Dishwasher
Whirlpool KUDC01TMBL1 Undercounter Dishwasher
Whirlpool KUDC01TMBL6 Undercounter Dishwasher
Whirlpool KUDC01TMWH1 Undercounter Dishwasher
Whirlpool KUDC01TMWH6 Undercounter Dishwasher
Whirlpool KUDC01TMWHO Undercounter Dishwasher
Whirlpool KUDC02IRBL0 Undercounter Dishwasher
Whirlpool KUDC02IRBL1 Undercounter Dishwasher
Whirlpool KUDC02IRBL2 Undercounter Dishwasher
Whirlpool KUDC02IRBL3 Undercounter Dishwasher
Whirlpool KUDC02IRBL4 Undercounter Dishwasher
Whirlpool KUDC02IRBS1 Undercounter Dishwasher
Whirlpool KUDC02IRBS2 Undercounter Dishwasher
Whirlpool KUDC02IRBS3 Undercounter Dishwasher
Whirlpool KUDC02IRBS4 Undercounter Dishwasher
Whirlpool KUDC02IRWH0 Undercounter Dishwasher
Whirlpool KUDC02IRWH1 Undercounter Dishwasher
Whirlpool KUDC02IRWH2 Undercounter Dishwasher
Whirlpool KUDC02IRWH3 Undercounter Dishwasher
Whirlpool KUDC02IRWH4 Undercounter Dishwasher
Whirlpool KUDC03FTSS0 Undercounter Dishwasher
Whirlpool KUDC03FTSS2 Undercounter Dishwasher
Whirlpool KUDC03ITBL0 Undercounter Dishwasher
Whirlpool KUDC03ITBL1 Undercounter Dishwasher
Whirlpool KUDC03ITBL2 Undercounter Dishwasher
Whirlpool KUDC03ITBS0 Undercounter Dishwasher
Whirlpool KUDC03ITBS1 Undercounter Dishwasher
Whirlpool KUDC03ITBS2 Undercounter Dishwasher
Whirlpool KUDC210S0
Whirlpool KUDC210S1
Whirlpool KUDC210S2
Whirlpool KUDC210S3
Whirlpool KUDC21CS1
Whirlpool KUDC21DS0
Whirlpool KUDC220T0
Whirlpool KUDC220T1
Whirlpool KUDC220T2
Whirlpool KUDC220T3
Whirlpool KUDC220T4
Whirlpool KUDC220T5
Whirlpool KUDC220T6
Whirlpool KUDC230B0
Whirlpool KUDC230BWH0
  #2 (permalink)
Old 08-27-2008, 06:23 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
Remove the cover to the chopper, sponge out the water, turn the water supply off, and run the dishwasher. Open door while the pump is running and observe the chopper to see if it is turning. If so, you probably have a polled reversed sidewinder motor. If not, you have a busted impeller on the motor.
__________________
  #3 (permalink)
Old 08-27-2008, 06:50 AM
Junior Member
Default
Quote:
What is a polled reversed sidewinder motor?
  #4 (permalink)
Old 08-28-2008, 03:09 AM
Senior Expert
APP Volunteer
Default
A lot of the sidewinder motors have stator windings that present a symetrical magnetic field. To get the motor to reliably start in one direction, they use a polling wire that polls the field in one direction. A power surge may have burnt open this wire. A sidewinder motor is one that mounts sideways.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
NO Water in Spray Arms garicao Dishwasher Repair 6 12-13-2009 12:59 PM
No water in spray arms chenke Dishwasher Repair 1 12-01-2009 09:11 AM
No Water coming from the spray arms chinook 22 Dishwasher Repair 4 10-22-2008 04:04 AM
pump pulsing, no water spray arms tappan Dishwasher Repair 0 03-11-2008 03:56 PM
DW arms won't spray the water rflores Dishwasher Repair 1 08-07-2007 09:24 PM
