Our dishawasher was working fine untill one morning when my daughter notice extremely hot water in the shower. The hot water heater thermostat had failed and we had 205 Degree hot water. Then the dishwasher would not cycle. Through research I found what I think to be the problem.. The NTC.. My question is :) do I have to remove the tank to get to the switch, or is there an easier way? quit
