| » Removing pump motor assembly |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: DU9700xr2 Brand: Whirlpool Age: More than 10 years
I am replacing the pump motor assembly. How do I take out the pump base? How does the new one seat so it will not leak?
Thanks, David |
Once the wires and hoses are removed the pump is only held in by 4 locking tabs. When you unlock them you can lift the pump up and out, replacement is the same just in reverse. Here is the part info and appliance breakdown:
Pump and motor assembly Parts breakdown
__________________
Those who don't learn from history are doomed to relive it! |
| Display Modes | |
| Pump/ Motor removal | dudedudeness | Dishwasher Repair | 4 | 05-17-2008 01:48 PM |
| How can I seperate the motor from the pump? | Sandman | Washer Repair | 3 | 08-29-2007 08:41 AM |
| pump and motor noise | Mike G. Siano | Washer Repair | 0 | 08-17-2007 09:04 AM |
| Removing rear bearing above brake assembly | Scott | Washer Repair | 2 | 08-04-2007 09:55 PM |
| Main pump motor is not activated. | gebman1 | Dishwasher Repair | 0 | 07-31-2007 10:05 PM |
