Circulation pump wouldn't run. Motor was 16 ohms at control module, but when connected, no voltage.
After a lot of swearing, found out the problem was the connector to the control module. The connection on the module is just the PCB & the socket connections get loose after several years.
Put some solder on to of the control module contacts to thicken it up a little & all is well.
Rgds - Chris
