The dishwasher was not cleaning as well as it should. Flow seemed low. Pulled the food chopper and found the screen clogged. The chopper was not turning. Seems the coupling half on the pump shaft has worn down to nothing and will not mesh with the chopper coupling. Is this a separate part or will the pump have to be replaced?
