| » Bosch Dishwasher stuck on one minute |
Model Number: SHU5306 Brand: Bosch Age: More than 10 years
I have a Bosch SHU5306UC12 dishwasher and it is stuck on 1 minute. I have read several blogs on this site with similar problem most being a control panel, however I have the control panel out and there are no burned solder points and it has the 10 amp relay. When I run the self test it gets to the heating and circulating test and never comes off of it to go to the draining test. I have to manually skip this test. The fault code comes up as a Zero which in the chart shows a bad flow switch. I replaced the flow switch today though it was only off by one ohm and still have the same problem. The heater, flow switch, hi limit and NTC ohms all test good and as listed. Is it possible the heater relay is bad on the control panel still though it is not burned? Any help would be appreciated. PS If I open the dishwasher while stuck on the 1 minute the water it hot, sudsy and is circulating. When I drain it by using the cancel mode it drains as it should so I know we do not have a plugged drain. I would appreciate any expertise you could give me.. Thanks
| Display Modes | |
| Bosch Dishwasher Stuck on 2H | SeattlePete | Dishwasher Repair | 37 | 03-23-2013 09:02 AM |
| bosch dishwasher stuck at final minute of cycle | Tomas41048 | Dishwasher Repair | 0 | 04-23-2010 11:24 AM |
| Bosch Dishwasher Stuck in Was | jreading | Dishwasher Repair | 0 | 03-20-2010 01:12 PM |
| Bosch dishwasher stuck at 8 min | Reddrum | Dishwasher Repair | 0 | 02-02-2010 03:18 PM |
