Discuss
Pump motor shaft part
 in
Dishwasher Repair
My mother-in-law's 18-inch Frigidaire dishwasher stopped spraying water at all and when it is turned on, the motor can clearly
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Pump motor shaft part
  #1 (permalink)
Old 07-10-2010, 04:01 PM
Junior Member
MrFixItAlready! is on a distinguished road
Default Pump motor shaft part
Model Number: FDR252RBB2   Brand: Frigidaire   Age: 5 - 10 years
My mother-in-law's 18-inch Frigidaire dishwasher stopped spraying water at all and when it is turned on, the motor can clearly be heard turning but with a sort of rasping sound. I took apart every assembly from inside of the dishwasher and could find no major damage, but the spray arm has melted plastic on one end. I figured I'd have to pick up a new motor assembly for her at that point, but they are not cheap and neither of us has the spare cash.
After another month or so, I realized that I had not removed the pump motor to see if anything was obviously wrong with it, though everything looked okay from the bottom with it installed. Upon removing the motor assembly, I found that the motor spins perfectly but that the plastic part that mates the motor shaft to the pump mechanism had broken at the base of the plastic mating shaft, just above the round, finned part of it. The spray arm must have gotten stuck on the heating element, which caused both the melting on the end as well as the plastic part to break. The part was easily removable, so I am now trying to find out what that mating part is called so that I can try to find it online (or anywhere else for that matter!) since it should be much less expensive than the entire motor assembly. The fins are right above the motor itself, facing down toward the motor, so my guess is that it is the cooling fan, but I can only find one other reference to this model's motor fan and it is on another forum and the responses say (yet again) that the whole assembly is only sold as a complete kit.
The AppliancePartsPros pump motor diagram page is here, with the motor assembly listed as F18,
Part number: AP3885612
There is no breakdown of this part and my searching so far has only found people saying that it is only sold as the entire kit, but I have no idea when my mother-in-law will be able to afford it, so I'm desperately trying to find out if there is a part number for the plastic shaft mating shown at the top of the motor in the first diagram I linked to above.
If there is no way to order that separately, can anyone think of a way to "jury-rig" it long enough to use the dishwasher until the motor assembly can be ordered and replaced? The high RPMs of the motor and the amount of force that is most likely required to send the water shooting through the spray arm is high enough that I doubt the ability of duct tape to come to the rescue (you don't hear that too often!). Since the bottom of the part seems to act as the motor's fan, I need to have both the two separate pieces joined together again so that the motor doesn't burn out.
Ads By Google
Related Models
Whirlpool FGP335EQ0
Whirlpool FGP335EW0
Whirlpool FGP335GN0
Whirlpool FGP335GN1
Whirlpool FGP335GQ0
Whirlpool FGP335GQ1
Whirlpool FGP335GW0
Whirlpool FGP335GW1
Whirlpool FGP335HN0
Whirlpool FGP335HQ0
Whirlpool FGP335HW0
Whirlpool FGP335VL0
Whirlpool FGP335VL1
Whirlpool FGP335VL2
Whirlpool FGP335VL3
Whirlpool FGP335VW0
Whirlpool FGP335VW1
Whirlpool FGP335VW2
Whirlpool FGP335VW3
Whirlpool FGP335YL0
Whirlpool FGP335YL1
Whirlpool FGP335YL2
Whirlpool FGP335YW0
Whirlpool FGP335YW1
Whirlpool FGP335YW2
Whirlpool FGP337GN0
Whirlpool FGP337GN1
Whirlpool FGP337GN5
Whirlpool FGP337GQ0
Whirlpool FGP337GQ1
Whirlpool FGP337GQ5
Whirlpool FGP337GW0
Whirlpool FGP337GW1
Whirlpool FGP337GW5
Whirlpool FGP337HN0
Whirlpool FGP337HQ0
Whirlpool FGP337HW0
Whirlpool FGP337KN0
Whirlpool FGP337KQ0
Whirlpool FGP337KW0
Whirlpool FGP337KW1 30" Gas Freestanding Standard Clean Range Electro
Whirlpool FGP345VL0
Whirlpool FGP345VL1
Whirlpool FGP345VL2
Whirlpool FGP345VW0
Whirlpool FGP345VW1
Whirlpool FGP345VW2
Whirlpool FGP345YL0
Whirlpool FGP345YW0
Whirlpool FGP355VL0
Whirlpool FGP355VL1
Whirlpool FGP355VL2
Whirlpool FGP355VL3
Whirlpool FGP355VW0
Whirlpool FGP355VW1
Whirlpool FGP355VW2
Whirlpool FGP355VW3
Whirlpool FGP355YL0
Whirlpool FGP355YW0
Whirlpool FGP357XL0
Whirlpool FGP357XW0
Whirlpool FGP357YL0
Whirlpool FGP357YL1
Whirlpool FGP357YL3
Whirlpool FGP357YW0
Whirlpool FGP357YW1
Whirlpool FGP357YW2
Whirlpool FGP357YW3
Frigidaire FGQ1442ES0 Frigidaire/dryer
Frigidaire FGQ332ES0 Frigidaire/gas Dryer
Frigidaire FGQB2152FE0 Frigidaire/dryer
Frigidaire FGQB4000FS0 Frigidaire/dryer
Frigidaire FGQBB30DS0 Frigidaire/dryer
Frigidaire FGR211AS0 Dryer - Frigidaire
Frigidaire FGR211AS1 Dryer - Frigidaire
Frigidaire FGR211AS2 Frigidaire/gas Dryer
Frigidaire FGR211AS3 Frigidaire/gas Dryer
Frigidaire FGR211AS4 Frigidaire/dryer
Frigidaire FGR211MAS0 Frigidaire/dryer
Frigidaire FGR221AS0 Dryer - Frigidaire
Frigidaire FGR231AS0 Dryer - Frigidaire
Frigidaire FGR231AS1 Dryer - Frigidaire
Frigidaire FGR231AS2 Frigidaire/dryer
Frigidaire FGR231AS3 Frigidaire/gas Dryer
Frigidaire FGR231AS4 Frigidaire/dryer
Frigidaire FGR231CAS4 Frigidaire/dryer
Frigidaire FGR311FS0 Frigidaire/dryer
Frigidaire FGR331AS0 Dryer - Frigidaire
Frigidaire FGR331AS1 Dryer - Frigidaire
Frigidaire FGR331KAS1 Frigidaire/gas Dryer
Frigidaire FGR341AC0 Frigidaire/dryer
Frigidaire FGR341AC1 Frigidaire/dryer
Frigidaire FGR341AS0 Dryer - Frigidaire
Frigidaire FGR341AS1 Dryer - Frigidaire
Frigidaire FGR641FS0 Frigidaire/dryer
Frigidaire FGR6600ES0 Frigidaire/dryer
Frigidaire FGR6600FS0 Frigidaire/dryer
Frigidaire FGRB5700DS0 Frigidaire/dryer
Frigidaire FGRB6600ES0 Frigidaire/dryer
Frigidaire FGRB6600FS0 Frigidaire/dryer
Frigidaire FGRB7800DS0 Frigidaire/dryer
Whirlpool FGS325RQ0 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ1 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD0 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD1 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD3 30" Gas Freestanding Self Clean Range
Whirlpool FGS335EN0
Whirlpool FGS335EQ0
Whirlpool FGS335EW0
Whirlpool FGS337GN0
Whirlpool FGS337GN1
Whirlpool FGS337GN5
Whirlpool FGS337GQ0
Whirlpool FGS337GQ1
Whirlpool FGS337GQ5
Whirlpool FGS337GQ6
Whirlpool FGS337GQ7
Whirlpool FGS337GW0
  #2 (permalink)
Old 07-22-2010, 07:26 PM
Junior Member
Default
Nobody has any ideas? I find that pretty hard to believe after looking at some of the other threads...
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer Timer shaft part request ForcedTQ Washer Repair 2 02-17-2010 04:55 PM
Kenmore leaking at pump shaft, doesn't wash takoateli Dishwasher Repair 3 12-23-2009 10:53 PM
Whirlpool washer leaking drain pump stuck to motor shaft, how to separate to replace? ennemm Washer Repair 1 05-03-2009 01:03 PM
Dishwasher pump shaft not turning oxymoron Dishwasher Repair 2 03-01-2009 07:21 AM
motor shaft play plubbers Dryer Repair 1 04-01-2008 01:02 PM
