I am swapping out the control assembly and have one contact point on the circuit board that is different from the original. on the lower left at p9 on the old board there is not a small metal male connector, only 2 small holes to receive something?? Question: when removing the small cable to disassemble, did the connector come apart from the board and do I need to replace that cable set?
