Discuss
thermal fuse blows on kitchenaid dishwasher
 in
Dishwasher Repair
Thermal fuse blows during heated water or drying cycle and leaves water inside the tub. Guess the heating element is
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » thermal fuse blows on kitchenaid dishwasher
  #1 (permalink)
Old 07-06-2010, 12:04 AM
Junior Member
itsmillertime is on a distinguished road
Default thermal fuse blows on kitchenaid dishwasher
Model Number: superba   Brand: Kitchen Aid   Age: More than 10 years
Thermal fuse blows during heated water or drying cycle and leaves water inside the tub. Guess the heating element is defective. Is there a way to measure the resistance of the element to determine if it is defective and other parts that could cause this symptom. M/N kuds24seal3.
Related Models
Jenn-Air SVD48600B RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD48600BC RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD48600P RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD48600PC RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD48600PF RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD48600PG RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD48600PK RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD48600PR RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD48600PT RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD48600PU RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD48600W RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD48600WC RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD8310S RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD8310S-C RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD8310SD Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SF RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD8310SG RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD8310SK RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD8310SR RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVD8310SU RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SVE47100B RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47100BC RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47100W RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47100WC RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47500B RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47500W RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47600B RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47600BC RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47600W RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE47600WC RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE87600B RANGE- S/C S/I DDRAFT ELE
Jenn-Air SVE87600W RANGE- S/C S/I DDRAFT ELE
Whirlpool SVF12FRHW00 VERTICAL FREEZER
Whirlpool SVF15NRHW00 VERTICAL FREEZER
Whirlpool SVF15NRHW01 VERTICAL FREEZER
Whirlpool SVF15NRHW02 FREEZER
Whirlpool SVF15NRJW00 FREEZER
Whirlpool SVF20NRKQ00 FREEZER
Amana SW22H REF - SXS/I&W
Amana SW22MBG REF - SXS/I&W
Amana SW22MBL REF - SXS/I&W
Amana SW22MBW REF - SXS/I&W
Amana SW25H REF - SXS/I&W
Amana SWDT22H REF - SXS/I&W
Amana SWDT25H REF - SXS/I&W
Amana SWP25H REF - SXS/I&W
Amana SWPD25H REF - SXS/I&W
White Westinghouse SWS1233CQ0 White Westinghouse/washer
White Westinghouse SWS1233CQ1 White Westinghouse/washer
White Westinghouse SWS1233CS0 White Westinghouse/washer
White Westinghouse SWS1233CS1 White Westinghouse/washer
White Westinghouse SWS1233HQ0 WASHER
White Westinghouse SWS1233HQ1 WASHER
White Westinghouse SWS1233HS0 WASHER
White Westinghouse SWS1233HS1 WASHER
White Westinghouse SWS1339CC1 White Westinghouse/washer
White Westinghouse SWS1339CC2 White Westinghouse/washer
White Westinghouse SWS1339HQ0 WASHER
White Westinghouse SWS1339HQ1 WASHER
White Westinghouse SWS1339HS0 WASHER
White Westinghouse SWS1339HS1 WASHER
White Westinghouse SWS1549AQ0 Washer - W.westinghouse
White Westinghouse SWS1549AQ1 Washer - West/grupo Famsa
White Westinghouse SWS1549AQ2 White Westinghouse/washer
White Westinghouse SWS1549AS0 Washer - W.westinghouse
White Westinghouse SWS1549AS1 Washer - West/grupo Famsa
White Westinghouse SWS1549AS2 White Westinghouse/washer
White Westinghouse SWS1649CQ0 White Westinghouse/washer
White Westinghouse SWS1649CQ1 White Westinghouse/washer
White Westinghouse SWS1649CS0 White Westinghouse/washer
White Westinghouse SWS1649CS1 White Westinghouse/washer
White Westinghouse SWS1649HQ0 WASHER
White Westinghouse SWS1649HQ1 WASHER
White Westinghouse SWS1649HS0 WASHER
White Westinghouse SWS1649HS1 WASHER
White Westinghouse SWS833HQ0 WASHER
White Westinghouse SWS833HQ1 WASHER
White Westinghouse SWS833HS0 WASHER
White Westinghouse SWS833HS1 WASHER
White Westinghouse SWS933AQ0 Washer - W.westinghse
White Westinghouse SWS933AQ1 Washer - West/grupo Famsa
White Westinghouse SWS933AQ2 White Westinghouse/washer
White Westinghouse SWS933AS0 Washer - W.westinghse
White Westinghouse SWS933AS1 Washer - West/grupo Famsa
White Westinghouse SWS933AS2 White Westinghouse/washer
White Westinghouse SWSG1031DQ0 White Westinghouse/laundry Center
White Westinghouse SWSG1031DQ1 White Westinghouse/laundry Center
White Westinghouse SWSG1031DS0 White Westinghouse/laundry Center
White Westinghouse SWSG1031DS1 White Westinghouse/laundry Center
White Westinghouse SWSG1031HQ0 LAUNDRY CENTER
White Westinghouse SWSG1031HQ2 LAUNDRY CENTER
White Westinghouse SWSG1031HQ4 LAUNDRY CENTER
White Westinghouse SWSG1031HS0 LAUNDRY CENTER
White Westinghouse SWSG1031HS1 LAUNDRY CENTER
White Westinghouse SWSG1031HS2 LAUNDRY CENTER
White Westinghouse SWSG1031HS4 LAUNDRY CENTER
White Westinghouse SWT1549AQ0 Washer - W.westinghouse
White Westinghouse SWT1549AS0 Washer - W.westinghouse
White Westinghouse SWT933AQ0 Washer - W.westinghouse
White Westinghouse SWT933AS0 Washer - W.westinghouse
White Westinghouse SWX703AQ0 Washer - W.westinghouse
White Westinghouse SWX703AQ1 Washer - West/grupo Famsa
White Westinghouse SWX703AQ2 White Westinghouse/washer
White Westinghouse SWX703AS0 Washer - W.westinghouse
White Westinghouse SWX703AS1 Washer - West/grupo Famsa
White Westinghouse SWX703AS2 White Westinghouse/washer
White Westinghouse SWX703CQ0 White Westinghouse/washer
White Westinghouse SWX703CQ1 White Westinghouse/washer
White Westinghouse SWX703CS0 White Westinghouse/washer
White Westinghouse SWX703CS1 White Westinghouse/washer
White Westinghouse SWX703HQ0 WASHER
White Westinghouse SWX703HQ1 WASHER
White Westinghouse SWX703HS0 WASHER
White Westinghouse SWX703HS1 WASHER
White Westinghouse SWXG831DQ0 White Westinghouse/laundry Center
  #2 (permalink)
Old 07-07-2010, 04:17 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Replacement parts for WHIRLPOOL KUDS24SEAL3 | AppliancePartsPros.com
Here is a tech sheet
http://www.servicematters.com/docs/w...%209743775.pdf
Element can be checked with a meter (670 ohms)
Make sure to remove one side of it. This prevents reading an alternate/parallel circuit path. Also check it for swelling/bubbles etc.
Usually they blow open.
When you replaced the fuse did you also replace it's wiring harness (Item22 in Section 3). This is very important.
Also here is a manual which may help
https://secured.whirlpool.com/Servic...LE/4317196.pdf
__________________
  #3 (permalink)
Old 07-07-2010, 10:43 AM
Junior Member
Default
Thank you for your prompt reply, information, and tips. The service manual and schematics are very useful.
With the fuse blowing I thought the heater might be shorted somehow but since it is a resistive component they usually open up like your tip suggested. The fuse only blows when the heated water and heated drying cycles are selected. This means that the heating element is activated where it appears to be drawing too much current causing the fuse to open. One thought is that the post for the heating element is shorting to ground where this could cause an over current condition but possibly unlikely. It is wise to order the insulating washers with the heating element for replacement?
When I replaced the first thermal fuse I did not replace the wiring since it looked like the factory one with similar connections and wire sizes. I will replace it the next time I work on it. This might be the reason the fuse is blowing during the heated water cycle and heated drying cycle.
Thank you very much for your assistance.
07/11/2010
I just removed the element where it measured 17.7 ohms. Then I measured the new one - 16.7 ohms. It appears that I was sent a defective part where the ends were slightly bent during the shipment. The original one has some wear concerns from the use of it where the element has some circular marks on the underside. This could be the bubbling effect you spoke of.
The original part from the manufacturer is 9743159 where the one sent is 9743495. This appears to be the correct cross referenced part.
Any ideas on the discrepencies?
Thank you in advance for your time.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Steps to replace thermal fuse in KitchenAid dual oven splach Oven Repair (including Ranges and Cooktops) 7 04-18-2013 05:07 PM
Kitchen Aid Dishwasher- Runs then blows Fuse dbshaw Dishwasher Repair 0 09-21-2009 10:43 AM
Thermal fuse repeatedly blows watchman Dryer Repair 1 09-04-2009 11:51 AM
dryer overheats, blows thermal fuse netsteeler Dryer Repair 7 06-03-2009 10:08 AM
dishwasher thermo fuse blows dude19572 Dishwasher Repair 1 05-15-2009 03:49 PM
