Dishwasher does not properly fill with water, and consequently spray / clean the dishes.
I put water in the tub by hand and it pumps out.
I took the cover off the float valve and it seems to be working properly.
My next step was to try to remove the bottom washer arm and lift up the filter to see if anything is collected or stuck in there, but I can't figure out how to remove the washer arm.
How do you get access to the tub from the top to clean it out?
How do I troubleshoot the float valve and filler valve to see if they are working properly?
