| » Maytag Drain Pump Won't Stop |
Model Number: mdbd850aww Brand: Maytag Age: 1 - 5 years
Model MDBD850AWW, ran fine until last evening when the wife complained about a, "funny noise." Appears that the pump keeps running after the water is gone. I removed down to the Rinse Arm Assembly, and found and removed much cruft (torn plastic, twist-tie, etc.) from lower wash arm and beneath.
Am reluctant to remove farther until asking the pros here...my current assumption is that whatever switch shuts the pump down once the water is gone is blocked by another strip of plastic junk, but then I've been all wet before. Would greatly appreciate any advice and suggestions. Ads By Google Related Models |
Here are your parts includes a wiring diagram
Replacement parts for MAYTAG MDBD850AWW Dishwasher - Undercounter | AppliancePartsPros.com As you can see on the wiring diagral there is not a water sense switch/device. Sounds like your control board may be shot. Try removing power from the unit for 10 minutes or so to see of it will reset.
__________________
| Display Modes | |
| Bosch dishwasher shu5316uc drain pump won't stop running | justkoz | Dishwasher Repair | 2 | 03-21-2010 03:14 PM |
| drain pump doesn't stop | wbyers | Dishwasher Repair | 0 | 10-30-2009 11:02 AM |
| Bosch drain pump won't stop | Steve A | Dishwasher Repair | 0 | 09-05-2008 08:43 AM |
| The drain pump won't stop | mandsmelott | Dishwasher Repair | 0 | 04-09-2008 07:41 PM |
| Spin and pump cycles stop and start, washer won't drain | grosshaus | Washer Repair | 1 | 03-31-2008 02:10 PM |
