My washer started to make a clunking sound when it starts to spin. As it goes faster, the noise diminishes as the spin gets faster until finally the noise stops and the spinning is fine. The machine works perfect in everyway other than this noise. I am single mom with limited income and cant afford someone to come in so I decided to try to take it aprt and find the problem.... I now have the machine completely disassembled and dont see anything broken, worn, or needing help...besides ME.. I thought the drive block.(looks fine..the 2 little grooves aren't worn) removed the brake and drive tube....looks fine....
havent opened the gear case yet..but been thinking about it.... I just hope I can put this all back together...:o Can anyone help me figure out what the best parts to replace ...while I'm at it?? HELP??:confused:
