| » GE Washer Tub Loose |
Model Number: WCRE6270H0WW Brand: GE Age: 1 - 5 years
I have a GE washer and the inner tub will not stay tight. The problems started when the machine got off balance. I replaced the hub nut thinking the threads may have been stripped. This lasted for two loads and the tub loosened again. I took it apart again and found that the ring split/split ring was worn very badly. I replaced this and retightened the hub nut. It did not stay tight even through one load. I noticed that the edges of the balance ring are very worn and was wondering if I should also replace this or if there are any other parts I should look at and possibly replace. Any suggestions you could provide would be much appreciated!!
| Display Modes | |
| Kenmore washer tub very loose | ron-e-g | Washer Repair | 4 | 03-17-2010 01:05 PM |
| Whirlpool Washer loose lid switch | Sunshine031294 | Washer Repair | 1 | 01-29-2010 06:15 PM |
| GE washer loose basket? | hawaan | Washer Repair | 3 | 09-22-2009 04:52 AM |
| back and sides of washer are loose... | iamelvisd | Washer Repair | 3 | 05-04-2009 03:52 PM |
| Washer Lid Switch Loose | Tabbycat333 | Washer Repair | 2 | 05-13-2008 06:50 PM |
