tdavis2783
#1 Posted : Saturday, June 19, 2010 8:36:41 AM(UTC)
tdavis2783
Dish washer wont drain. I can manually press solinoid at the correct time during the cycle and it will drain. solinoid moves freely. how can i test to make sure the solinoid is faulty. Thanks in advance
#2 Posted : Saturday, June 19, 2010 11:15:46 AM(UTC)
Here are your parts includes a wiring diagram
Replacement parts for MAYTAG MDB2400AWT Dishwasher - Undercounter | AppliancePartsPros.com
Check for voltage across it.
If it gets 120 volts when it should and is not pulling in then it is toast.
If it does not get voltage odds are the timer is toast.
