| » GE dishwasher, GSD500X |
Model Number: GSD500X-66wb Brand: GE Age: More than 10 years
It fills with water and the dial moves through the cycles but it doesnt run.
Remove the bottom panel and check if the motor makes a humming noise when it should run.
If it does, the pump & motor assembly has to be replaced. If it does not, check for 120 VAC at the motor plug and post the results. - The pump & motor assembly Part number: AP2616850 Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Quote:
Does the pump run during the drain? Gene.
__________________
You did not answer this question.
__________________
ooops sorry, not sure. I know that when I was using it the dishwasher did not drain at all. It would just overflow. We have tried taking the catch and cleaning it, making it free of gunk. Hope that answers your question somewhat.
Thank You |
I need you to remove the bottom panel, start the dishwasher and check if the motor will work or just will make a humming noise.
__________________
Ok I will do that! I will have to do it the morning and let you know thanks
| Display Modes | |
| Dishwasher will not empty no lights on front of dishwasher except led lines | badtothebone | Dishwasher Repair | 0 | 05-13-2010 02:17 PM |
| Dishwasher will not empty no lights on front of dishwasher except led lines | badtothebone | Dishwasher Repair | 0 | 05-13-2010 02:14 PM |
| dishwasher spray arm melted to heating element and now dishwasher not working | msphillips2 | Dishwasher Repair | 0 | 05-08-2010 10:21 AM |
