Discuss
control lights flashing on dishwasher
 in
Dishwasher Repair
Marianne, Sounds like your dishwasher has a lot of hard water deposits build up and it needs cleaning. You can
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » control lights flashing on dishwasher
  #31 (permalink)
Old 10-16-2012, 04:52 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Marianne,
Sounds like your dishwasher has a lot of hard water deposits build up and it needs cleaning. You can use just a regular white vinegar. You also can use Affresh dishwasher cleaner.
- The Affresh dishwasher cleaner Part number: AP5176437
Ads By Google
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #32 (permalink)
Old 10-19-2012, 11:35 AM
Junior Member
dandan74 is on a distinguished road
Default
Hi, Gene,
Can you please give me a link the techsheet of kitchenaid KUDK03CTSS0?
It's normal light flashing. I have posted in a seperate post but you didn't reply. I want to do a diagnosis to see whether I need a new keypad, control panel or control board.
-Tiewen
Quote:
Originally Posted by Gene View Post
Marianne,
  #33 (permalink)
Old 10-19-2012, 04:14 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by dandan74 View Post
Hi, Gene,
-Tiewen
Hi Tiewen,
Most likely the solution is to replace the console but there is a small chance for the control board to be bad as well.
Here are the breakdown diagrams and Parts for Whirlpool KUDK03CTSS0 Dishwasher - AppliancePartsPros.com
File Type: pdf Tech Sheet - W10082651 - KUDJ02CRBS3.pdf (250.1 KB, 6 views)
__________________
  #34 (permalink)
Old 10-21-2012, 02:53 PM
Junior Member
Default
Hi, Gene,
That's for the techsheet. I have a question about the keypad test.
For the following chart, does it mean by this:
DELAY HOURS P1-12 P1-2
Does it P1 should be shorted to P12 and P2 as well when I pressing the delay hours key? Otherwise, it should be open?
-Tiewen
Hi Tiewen,
  #35 (permalink)
Old 10-22-2012, 03:19 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Tiewen,
You probably overlooked the first and most efficient part of the "Checking keypad operation" instructions on the second page. Perform it and you'll see which part is bad.
__________________
  #36 (permalink)
Old 10-27-2012, 08:19 PM
Junior Member
Default
I didn't the keypad function check. The control is fine.I tried to test the keypad connectivity with the chart with no luck.I think it does not apply to my model. However, after I did all this and started to place the order for a new keypad.I plugged the keypad ribbon back to the control board and clicked "start",the dishwasher start running again. No flashing. Is this just a bad connection because of the repair didn't plug the ribbon firmly?I hope the dishwash does not choke again. If it does, would it be the control or keypad?
Hi Tiewen,
  #37 (permalink)
Old 10-29-2012, 04:05 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
...If it does, would it be the control or keypad?...
Hopefully it will last but if not then 99% for the keypad.
__________________
  #38 (permalink)
Old 11-06-2012, 01:06 PM
Junior Member
Default
You were right. The fix didn't last. Ordered parts and replaced the keypad yestersday. Problem fixed. Thanks for the help!
  #39 (permalink)
Old 11-06-2012, 02:54 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome. I'm glad you were able to fix it.
__________________
  #40 (permalink)
Old 11-24-2012, 01:04 AM
Junior Member
alhero is on a distinguished road
Default Blinking lights
Hi Gene:
I know this is an old posting but I have the same problem with the Normal, light china and cancel light blinking. I have a Kitchenaide Model KUDS02FRSS1. Could you send me a tech sheet for that model so that I can perform some troubleshooting.
Thanks in advance for all your help
Al
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dishwasher control lights flashing Sam B Dishwasher Repair 0 08-10-2009 02:41 PM
Flashing control lights & code F-70 ernstbankst Dryer Repair 0 03-16-2009 05:40 PM
Control board lights flashing akisich Refrigerator & Freezer Repair 1 09-07-2008 03:25 PM
Flashing Lights on Control panel pfleyva Dishwasher Repair 0 05-12-2008 10:43 AM
problem with dishwasher control board flashing lights bugman026 Dishwasher Repair 0 04-20-2008 10:03 AM
