Discuss
Quiet Partner Two no power to control panel
 in
Dishwasher Repair
Hello, I recently posted this and was told maybe a thermal fuse. I just found out that I can find
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Quiet Partner Two no power to control panel
  #1 (permalink)
Old 06-10-2010, 11:00 AM
Junior Member
jessejames1075 is on a distinguished road
Default Quiet Partner Two no power to control panel
Brand: Whirlpool   Age: 5 - 10 years
Hello, I recently posted this and was told maybe a thermal fuse. I just found out that I can find reset codes behind toe plate. I will check tomorrow. I have power to the control panel but no lights or commands are responding. Is there something else I can do? Im trying to find a schematic to locate the thermal fuse, since it is one of the less expensive parts to try. Thanks, James
Ads By Google
  #2 (permalink)
Old 06-10-2010, 11:32 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Please do not start a bunch of new threads as it will just get confusing.
I looked at your other post to get the model number (GU1200).
Replacement parts for WHIRLPOOL GU1200XTLS3 Undercounter Dishwasher | AppliancePartsPros.com
Fuse is Item 6 in Section 2. Remove it and check it with a meter if it is blown be sure to use the new wiring harness that comes with the replacement.
Here is the tech sheet
http://www.servicematters.com/docs/w...%208537797.pdf
This should also help
https://secured.whirlpool.com/Servic...LE/8178022.pdf
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
control-elec panel no power Dusan Vujinovic Oven Repair (including Ranges and Cooktops) 0 04-10-2010 05:51 PM
Whirlpool Quiet Partner 2 no power lordcrom Dishwasher Repair 1 07-21-2009 02:03 PM
Quiet Partner IV has no power Hercules Dishwasher Repair 3 05-26-2009 08:41 AM
No power to control panel jwes Dishwasher Repair 2 05-18-2009 06:18 PM
Whirlpool gold quiet partner III no power pops Dishwasher Repair 1 05-08-2009 11:54 AM
