Discuss
Need Help With Replacing KitchenAid Blender Coupling
 in
Blender Repair
I am a novice but pretty logical. The instructions are clear but when I try to remove the metal coupling,
Appliance Repair Forum > Appliance Repair Help > Blender Repair » Need Help With Replacing KitchenAid Blender Coupling
  #1 (permalink)
Old 06-07-2010, 08:31 AM
Junior Member
Pokalong is on a distinguished road
Default Need Help With Replacing KitchenAid Blender Coupling
I am a novice but pretty logical. The instructions are clear but when I try to remove the metal coupling, it just keeps turning. I can't get it to move counterclockwise or clockwise without turning the whole mechanism. See the attachment for what I am dealing with.
The black rubber part disentegrated.
  #2 (permalink)
Old 06-13-2010, 02:13 AM
Junior Member
gbell12 is on a distinguished road
Default
yeah, as far as I'm concerned the instructions are bogus - how could you turn the coupler 1/4 turn when its mounted on a shaft that turns freely?
  #3 (permalink)
Old 06-13-2010, 02:23 AM
Junior Member
Default
Wow, my mistake. It works.
"Turn coupler 1/4 turn" doesn't mean that the shaft has to be stationary while you turn it... you literally turn it and bend up the next bit of coupler edge with the screwdriver until it magically loosens and you can unscrew it (clockwise).
I've repaired small appliances (unprofessionally) for 30 years and this is the most mysterious thing I've seen! You must keep bending the edge of the coupler up, and it suddenly loosens and can be spun off...
  #4 (permalink)
Old 06-23-2010, 10:40 AM
Junior Member
Thumbs up It Worked!
Thanks for the response. I kept at it and finally realized that the tip of the screwdriver should not stop at the drive shaft and the screwdriver was just a leverage tool. It only took 4 turns after that!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How to replace coupling on KitchenAid blender Admin / APP Team Blender Repair 37 12-17-2016 06:39 AM
Coupling Drive for Kitchen Aid blender Mgordon Blender Repair 6 12-08-2009 11:26 AM
