I have a whirlpool duet sport that is three years old. A few days ago we found it powered down with the door locked. After a manual unlatch I ran it through the diagnostics (a F20 error code was the only recorded error) and at the end it would not perform the high speed spin. I have tried running it through a few different cycles, but they all end with the same result. It all goes fine until it's time to spin at which point it simply powers down and won't turn back on until I reset it. There are no error codes when the power fails, it just turns off. I have checked the filter and flushed the hoses, checked the harness wire connections, and made sure the pressure hose was not obstructed. Any help for a newbie to this forum is much appreciated
