| » How to replace coupling on KitchenAid blender |
I almost quit the repair thinking that I needed thin wrench to hold the shaft. It took about 12 bites with the screwdriver to pry the old coupler off, leaving the soft metal threads in the hard metal threads of the shaft. The screwdriver fulcrum is on the hard metal of the motor so the plastic of the case isn't damaged. Weird way to start a repair, but it works.
It took more struggling than the initial directions implied, but it did eventually work, so stick with it! For me, just the screwdriver wasn't enough, I needed to hold the shaft with needle nose pliers and used vice grips on the coupler. The coupler was pretty mangled by the end, but the shaft was fine.
Quote:
Stepup, Some of the parts are the same. I will help you out in getting the correct part. What part are you looking for?
__________________
Need a part? Buy appliance parts from us. Fast delivery and great prices. Thank you for supporting our free repair help forum. |
I wasn't able to remove it using the instructions posted (i.e. prying up the adapter with the screwdriver while turning). Maybe I just don't have the finese. There are flats on the shaft under the nut that you can hold on to. I cut a 7mm slot in a thin piece of metal and and held it from turning with that. Could also be done by sacrificing a 7mm open-end wrench and grinding it down if necessary.
Quote:
Thanks. |
See this pic
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Coupling Drive for Kitchen Aid blender | Mgordon | Blender Repair | 6 | 12-08-2009 11:26 AM |
