| » Kitchenaid Pro 600 repair question |
Model Number: Pro 600 Brand: Kitchen Aid Age: 1 - 5 years
Hi - I have a Kitchen Aid Professional 600 series mixer. The planetary housing has slid off, and will not remain in place when put back on. All the information I have found, including the repair manual show the main shaft as attached to the housing, and then the shaft is secured to the mixer. On mine, however, the housing has slid off the main shaft, and there is no obvious way to secure it back on. On different models, there is a pin that inserts through the housing through a hole in the main shaft, but the Pro 600 does not have this.
Any help would be greatly appreciated! Ads By Google Related Models |
Hi Debbie - After carefully analyzing the schemeatics for the mixer it became clear that the planetary assembly is not supposed to detach from the main shaft in that way, and there does not appear to be a clear fix - I'm not sure how it stays on - must be friction.
The good news is that I was able to buy a new planetary assembly complete with shaft for less than $20. Installing it was not overly complicated, though you need to remove a tension ring with tension ring pliers to get it off. I needed to get a new ring form the hardware store to reassemble it. I found a repair guide for the mixer online which was helpful. If you aren't good at this type of thing, I bet you could find someone to do it for you pretty easily - the whole fix took maybe 30 minutes, but you are opening up the mixer, so need to be confident. Hope this helps! Last edited by skixc : 02-17-2012 at 10:46 AM. Reason: typo |
You are right!The words you write is so cool!Then I know the key in this questions!
You are a good person who can sharing the question with others,Thank a lot!I will have a try! ------------------------------------------------------- Last edited by gpseller : 12-13-2012 at 10:23 PM. |
| Display Modes | |
| Repair rip off question | agalliath | Refrigerator & Freezer Repair | 5 | 10-25-2010 09:57 AM |
| KitchenAid fuse wiring question | TerryChandler | Dishwasher Repair | 0 | 07-15-2010 06:02 AM |
| 5 speed Kitchenaid blender question | ohanahorse | Blender Repair | 0 | 04-19-2010 03:57 PM |
| Repair question | rsingh2483 | Refrigerator & Freezer Repair | 1 | 02-22-2009 05:10 PM |
| Help with a repair question | jillc | Oven Repair (including Ranges and Cooktops) | 2 | 02-21-2009 01:36 PM |
