Kitchenaid Pro 600 repair question
Hi - I have a Kitchen Aid Professional 600 series mixer. The planetary housing has slid off, and will not remain in place when put back on. All the information I have found, including the repair manual show the main shaft as attached to the housing, and then the shaft is secured to the mixer. On mine, however, the housing has slid off the main shaft, and there is no obvious way to secure it back on. On different models, there is a pin that inserts through the housing through a hole in the main shaft, but the Pro 600 does not have this.
Any help would be greatly appreciated! |
Hi
I am having the same problem with my kitchen aid Professional 600 series mixer, the planetary housing will not stay on. Did you find an answer to this? Thanks, Debbie D |
part replacement
Hi Debbie - After carefully analyzing the schemeatics for the mixer it became clear that the planetary assembly is not supposed to detach from the main shaft in that way, and there does not appear to be a clear fix - I'm not sure how it stays on - must be friction.
The good news is that I was able to buy a new planetary assembly complete with shaft for less than $20. Installing it was not overly complicated, though you need to remove a tension ring with tension ring pliers to get it off. I needed to get a new ring form the hardware store to reassemble it. I found a repair guide for the mixer online which was helpful. If you aren't good at this type of thing, I bet you could find someone to do it for you pretty easily - the whole fix took maybe 30 minutes, but you are opening up the mixer, so need to be confident. Hope this helps! |
Thank you for responding and I did order the part, I will try!
Thanks again, Debbie |
My Maytag died and I was told it was a $600 repair. The matching dryer is in perfect condition, and I'd like to donate it somewhere rather than have it thrown out.
Thanks for your article!
You are right!The words you write is so cool!Then I know the key in this questions!
You are a good person who can sharing the question with others,Thank a lot!I will have a try! ------------------------------------------------------- |
___________________ Best deals on latest series for buy dvds in our shop can let you get more discount! |
| All times are GMT -7. The time now is 07:40 PM. |
