Discuss
KSB5WH coupling replacement necessary?
 in
Blender Repair
Our KSB5WH blender has a very loose coupling that wobbles. It rotates when the blender is on but no blender
Appliance Repair Forum > Appliance Repair Help > Blender Repair » KSB5WH coupling replacement necessary?
  #1 (permalink)
Old 11-07-2010, 10:47 AM
Junior Member
gingerburke is on a distinguished road
Default KSB5WH coupling replacement necessary?
Our KSB5WH blender has a very loose coupling that wobbles. It rotates when the blender is on but no blender jar is on it. When the blender jar is on it, it sounds like the coupling is still rotating and the motor is still working, but no blending is taking place. Is the problem a worn out coupling? Is there a way to tighten the coupling and see if this solves the problem?
Ads By Google
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
coupling replacement on model# KSB560 Rick Smith Blender Repair 0 09-08-2010 11:03 AM
coupling replacement / rubber gasket found a1putt Washer Repair 3 06-19-2010 12:27 PM
kenmore 60 series not spinning after motor coupling replacement orion359 Washer Repair 1 03-31-2010 04:42 PM
Motor Coupling replacement ErinK Washer Repair 1 04-14-2009 04:12 PM
